hey guys i just bought a 04 blaster i need help
Old 07-24-2003 | 03:54 PM
stroked280's Avatar
Default hey guys i just bought a 04 blaster i need help
allright i have the toomey b1 kit with the pipe silencer and the 310 main jet, ( not intsalled) and i want to do k&n filter and outer wear, with reeds and reed spacer, and last a boost bottle how much bigger would i have to go with the main jet to richen up the mixture alittle bit cause i had the same set up with my last blaster and i seized the motor cause the reeds require a larger jet? thanks
Old 07-24-2003 | 04:08 PM
BLASTERDEVIL2's Avatar
I would try to give toomey a call and see what they say. Or go out and get your self a 30mm carb. and don't waste your money on a boost bottle for a blaster it don't do anything.
Old 07-24-2003 | 04:21 PM
Peltrax's Avatar
I would probably say the 310 would work your not really increase air hardly at all...I would stick with the foam filter they give you and get a v force reed valve 2...i run a 300 on mine and it runs great
Old 07-25-2003 | 06:25 PM
blasterdude13's Avatar
i heard that boost bottles dont do much either and i agree with blasterdevil
Hankey Pankey
26
10-18-2020 04:50 PM
02Chevrolet
1) Engine problems..
06-23-2015 01:12 AM
yellowpolaris
06-21-2015 12:13 PM
OLDSTER
01-09-2001 11:13 PM
