WARRIOR JETTING QUESTION....
Old Jul 25, 2003 | 08:49 AM
HILLWARRIOR's Avatar
Default WARRIOR JETTING QUESTION....
I HAVE A 2000 WARRIOR WITH E-SERIES PRO MEG,K@N FILTER,AIR BOX LID OFF AND A 150 MAIN JET AND I LIVE IN MINNESOTA.WHEN AT IDLE IT MAKES A SOUND LIKE A BACK FIRE AT THE CARB BOOT(not constantly)AND THEN AT FULL THROTTLE IN 6TH IT SPUTTERS EVER ONCE IN A WHILE.NOW SHOULD I GO BIGGER ON THE MAIN?OR DO I MOVE THE CLIP ON THE NEEDLE UP OR DOWN?IVE CHECKED FOR AIR LEAKS IN THE CARB BOOT AND THATS NOT THE PROB.......ANY HELP WOULD BE GREAT.......................................P.S.so rry i didnt know i was yelling..oops!!!!
Old Jul 25, 2003 | 12:12 PM
valve adjust ment?timeing?.......anybody!!![img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 25, 2003 | 12:53 PM
DietCokeOfEvil's Avatar
Have you done a spark plug check to see if the electrode is white or brown/black? It should be gray if you are running a good mixture. White would be lean and brown/black rich... I'm not sure what altitude Minnesota is but for some reason I want to associate it with mountains... (higher the altitude the smaller the jet you need, 150 is generally associated with altitudes around sea level to +1500 feet I believe) of course when you live in Oklahoma like I do, a good sized hill looks like a moutain [img]i/expressions/face-icon-small-happy.gif[/img]. When I jetted my Warrior I went with a 150, I started with a 148 but it was very choppy... the 150 solved that (Im at +1200 feet or so). I wish I could remember the logic behind the clip adjustment on the needle but I just followed the instructions that came with the dyno jet kit I ordered and while I remember that I moved the clip 2 positions I cant recall if it was up or down. The dyno jet kit has a nice trouble shooting guide as well, sorry I'm not at home or I would pass on what it says about the stuttering problem.
Another suggestion is to do an advanced search on this forum for Warrior and Jet, simultaneously and you will find alot of threads about Warrior jetting.
Old Jul 25, 2003 | 01:22 PM
its around sea leval here to.i know what your talking about seeing a good size hill and thinking mountain.thanx for the info scott i think i will move my clip on the needle up at first then try moving it down.i tried putting my stock jet in but it just made it worse on top end.if you happen to find the trouble shotting chart that came in the jet kit let me know......thax again.
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
