Lots Of torque, no speed.
Old Aug 1, 2003 | 09:13 AM
  #21
UBETRUN's Avatar
Default Lots Of torque, no speed.
I think you are getting mixed advice on jets, DJ numbers are different than Mikuni numbers. If you have a DJ needle and jets, you should not need to go over 146/148 with your mods. I still maintain that you are running rich and that's why you don't have the same top end that you did when you were stock. If your off-idle and mid range performance are good, leave your pilots and needles alone, focus your attention on those main jets since they control the top end performance.
Old Aug 2, 2003 | 04:26 PM
  #22
INSeaRChOFDUNez's Avatar
i finally tested my bike and its running beter.. maybe alil rich but top end is way better.. now im running 170/175 dj mains. overall it was an improvement.
Old Aug 5, 2003 | 09:00 PM
  #23
i took my bike on some sand dunes in baja "PunTa ColoNet", pretty fun dunes specially the straight up hills. well it died on me twice it was way too rich so thanks to my prepared thinking i brought along my jets and my tools and went back to 148 150. so ill stay there until i get new carb(s). and if i can say I hATE JETING!
Old Aug 5, 2003 | 09:34 PM
  #24
ALIENraptor's Avatar
Probably asked before but what elevation are you at? I am at sea level and when i used to have my DJ kit, I had a 148/150, 3rd notch, 3 turns out on the a/f, 27.5 pilots, A lid, no snorkle and a one inch oval hole in the rear of the lid and it ran PERFECT!
Old Aug 5, 2003 | 11:23 PM
  #25
im at the beach
maybe 100ft at most
Old Aug 5, 2003 | 11:25 PM
  #26
doesnt the pilot jet affect throtle response??
Old Aug 6, 2003 | 12:31 AM
  #27
UBETRUN's Avatar
Have either of you even tried 146/148?
Old Aug 6, 2003 | 01:23 PM
  #28
yeah i have but it runs too lean.. thats what made my pipes go purpleblue reddish color. so i went up to 148/150. besides thats the set up for the stock box with snorkle just with the flaps cut of from the inside.
Old Aug 7, 2003 | 07:19 PM
  #29
TheQuadSport230's Avatar
Why don't you adjust you quad checking your spark plug?
Old Aug 7, 2003 | 09:02 PM
  #30
wshrdskin's Avatar
Originally posted by: sixsixT
wshrdskin was running 150/155 in his but I'm not sure if it was after a cam and piston. I would try those anyway, 170/175 sounds like to much to me also.
That was before and after the stock bore 11:1 and cam. I't ran great at 148/150 with pipe and filter no lid. Same results at 150/155. With the mods I have now I run 170/175 Dyno Jets. That seems way high to me for your setup.
