YFZ NEEDLE
Old Jul 29, 2003 | 02:44 AM
yfzpilot's Avatar
Default YFZ NEEDLE
OK I put a 168 main in my yfz now i need to change the clip on the needle. I have know idea how to or where it is is there someone who can please help me. Also do you change the pilot the same way you change the main jet? any help would be great thanks....... The more detailed the better not to good at carbs THANKS.
Old Jul 29, 2003 | 04:27 AM
iluv2fly's Avatar
Default YFZ NEEDLE
To get to the needle you pull out the 2 allen screws on the very top of the carb and remove the cover. When the cover is removed you will see a gold allen screw down in there. Take out the gold allen screw and you will see the needle underneath it. Take a pair of needle nose pliers and remove the needle to make changes. The pilot jet can be changed by taking out the plug in the bottom of the carb. It is located by the main jet and you will need a small straight blade screwdriver to remove it. You do not have to take the float bowl off to change the pilot jet just remove the plug at the bottom with a 17mm wrench and you will see it located by the main jet.
Old Jul 29, 2003 | 10:52 AM
yfzpilot's Avatar
Default YFZ NEEDLE
Thanks so much. What about the throttle cable do i need to take that off to get the carb out? If so how? Thanks for the reply.
Old Jul 29, 2003 | 06:39 PM
erich's Avatar
Default YFZ NEEDLE
You do not need to take the carb all the way out, just turn it sideways. I removed the airbox then pulled the carb back from the engine, that gives you enough room to turn it. Turn the bottom towards the shifter side and then you can access the top from the other side. i took off the side plastic to make it easier while doing the top. you probably need to grind about 1/8 inch off the top of the needle if you go down to #6.
Old Jul 30, 2003 | 12:30 AM
yfzpilot's Avatar
Default YFZ NEEDLE
Thanks so much for the info I will give it a go and let you know. Thanks again
speedbuff
13
Nov 11, 2020 10:16 AM
Dammar
Apr 20, 2016 06:03 AM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
