popping raptor
Old Jul 30, 2003 | 10:41 PM
jaws03's Avatar
Default popping raptor
ok i bought a new trinity stage IV pipe and but it on tongiht and when i started it poped a little when i gave it gas i drove it a little then checked the plug it was not rich a littlelean but then i put a new one in then it would barely start and run popping and backfireing is that casue i dint jet it right?? it came with two sets of jets im running stock air filter maybe ill take the snorkle off but that is y it was popping right and do i need those gaskets that came off the stock head pipe from the motor on the new ones and that new pipe is alot louder than my R4 [img]i/expressions/face-icon-small-smile.gif[/img])
Old Jul 30, 2003 | 11:41 PM
DRAG660's Avatar
i have a trinity pipe on my raptor i havent jetted my raptor and mine pops when i turn it off but still runs fast
Old Jul 31, 2003 | 12:26 AM
jaws03's Avatar
wonder why mine does oh well giong to rejet anywase
Old Jul 31, 2003 | 12:29 AM
spacollie's Avatar
Popping not good. To lean. Bigger jets.
Old Jul 31, 2003 | 12:31 AM
jaws03's Avatar
ok thanks
Old Jul 31, 2003 | 12:36 AM
spacollie's Avatar
If you remove your snorkle you may run even leaner due to more air being sent into your engine. Fix the problem you have now before doing anything else. Mod in stages as so you know where you are and what does good or what does nothing at all.
Old Jul 31, 2003 | 12:37 AM
HappaRap's Avatar
Lazy Boy Rider!
You guys need to rejet. popping is a lean condition, jet up before you burn it up.
Old Jul 31, 2003 | 11:54 AM
Starky's Avatar
How about a slight hesitation when you give it the gas. All I've done is remove the snorkle. With the R4 and GYTR foam filter and STOCK jets I am still running strong but I think ther is a lot more potential if I go up a bit with the jets.
Old Jul 31, 2003 | 12:56 PM
BigScary's Avatar
then you are WAY lean...........My brother is running stock everything except for he removed the baffle and his is soo lean that it doesn't run right!..........it feels weak to me!
and it hesitates pretty bad when you first gass it.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
black_thunder
Sep 22, 2015 07:59 PM
