HITTING REV LIMITER LIKE A WALL!!!!
Old Aug 1, 2003 | 04:29 PM
amsoil123's Avatar
Default HITTING REV LIMITER LIKE A WALL!!!!
I just put the Curtis Sparks full exhaust on my YFZ 450.The main is a 170, the needle is on #5,did the cam mod.Befor I put pipe on I never hit the rev limiter,now I hit it in every gear [img]i/expressions/face-icon-small-disgusted.gif[/img]Did I miss something or is this what the pipe mod dose????[img]i/expressions/face-icon-small-confused.gif[/img]The power is unreal,but that rev limiter,if it is the rev limiter,has got to go!! [img]i/expressions/face-icon-small-mad.gif[/img]
Old Aug 1, 2003 | 04:48 PM
amsoil123's Avatar
Anybody have an idea,[img]i/expressions/face-icon-small-frown.gif[/img]I don't have a clue.......and that would be an under statment. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 1, 2003 | 04:50 PM
JakalWarrior's Avatar
When you look at most of the dyno graphs you see that the power starts to fall a ways before the redline and its not too bad before the peak either. You have a pretty good area to work with. Just shift earlier.
Old Aug 1, 2003 | 05:31 PM
Toyguy's Avatar
Okay my Z400 does the same with the Rev limiter. I lowered the front sprocket 1 tooth. My question is, is it real bad to hit the rev limiter? Mine does it in every gear too.
Old Aug 1, 2003 | 05:41 PM
amsoil123's Avatar
The rev limiter is there to prevent you from over revving the engine.I hit mine befor on the starting line of a drag race,thought nothing of it. But it seems I hit it now when I shouldn't be. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Aug 1, 2003 | 05:44 PM
dragracer789's Avatar
Just buy an aftermarket CDI box with no rev limit. (if they make one for it yet)
Old Aug 1, 2003 | 07:10 PM
PredFan's Avatar
The aftermarket pipe allows the quick-reving YFZ to rev even faster, because of the freer flow vs. stock pipe. This happens on a alot of quads with aftermarket pipe. You may have been hitting the limiter in stock trim too, it is just less pronounced with the stock pipe, so you don't pay attention to it. The most important thing to do is to determine that your bike is still achieveing the appropriate RPMS before hitting the limiter. If not, it could be an air intake issue also.
Old Aug 1, 2003 | 11:38 PM
amsoil123's Avatar
Thank's PredFan.[img]i/expressions/face-icon-small-wink.gif[/img]I guess I'll be needing an aftermarket cdi box,when they hit the market.
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
black_thunder
Sep 22, 2015 07:59 PM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
