raptor idol
Old Aug 4, 2003 | 01:49 AM
StockRappy's Avatar
Default raptor idol
my raptors idol is set high enough to run, but sometimes when i ride it, it likes to stall, i have no clue why it is doing this and it is getting very annoying, it usually happens when i pull the clutch in from going up hills or riding, and sometimes when i ride its completely fine other then the stupid tranny, anyone had this problem, whats wrong and how much will it cost?
Old Aug 4, 2003 | 05:51 PM
shlekter's Avatar
Default raptor idol
did u buy your raptor new
Old Aug 4, 2003 | 06:25 PM
Starky's Avatar
Default raptor idol
I'm not sure what rpm it's supposed to be set at, but it is supposed to idle high. If you turned down your idle screw because you thought it was to high it will stall just like you explained. The bad thing about it is it will destroy your starter.
Old Aug 4, 2003 | 06:27 PM
slappie's Avatar
Default raptor idol
Does it happen only when you have the clutch pulled in?
It could be that your clutch is going out. Have you ever replaced the OEM clutch? It could be heating up to the point that it is not letting it fully disengage, and then it is still putting a load on the engine even with the clutch pulled in.
Something to think about I guess.
Old Aug 4, 2003 | 06:39 PM
shlekter's Avatar
Default raptor idol
my warrior does that 2 after running wot 4 a while and u let off and pull the clutch it dies i think i need a new clutch bc 2 put it in nuetral u have 2 rev it bc the clutch doesnt fully disengage
Old Aug 4, 2003 | 07:59 PM
spacollie's Avatar
Default raptor idol
Is your clutch adj. properly?
Old Aug 4, 2003 | 08:01 PM
shlekter's Avatar
Default raptor idol
yea the handle is tight with t he cable
Old Aug 4, 2003 | 08:04 PM
spacollie's Avatar
Default raptor idol
I would start by setting to the proper RPM just so then you know where to start. There should be a little bit of play in your lever, not totally tight.
Old Aug 4, 2003 | 08:07 PM
shlekter's Avatar
Default raptor idol
i dont have acces 2 a tach how would i know whats right?
Old Aug 4, 2003 | 08:13 PM
spacollie's Avatar
Default raptor idol
You need a digital meter with a amp clamp. Mac tools has a good one. There is a rpm setting on the meter and you clamp lead on to your spark plug cable in the direction of flow. The arrow points toward the plug. Fire up your bike and the meter will read your rpm,s. To buy a meter for this purpose would be useless but any automotive shop or dealer should have one.
