mild 686
Old Aug 8, 2003 | 12:16 PM
ccgrady's Avatar
Default mild 686
I need to know how to build a mild 686 kit. Like what size and compression piston, what size cam and so on. I really dont wont to go full out and the most important thing is for it to be reliable. i wouldn't mind running 50/50 race at most. Please let me know your thoughts.
Old Aug 8, 2003 | 01:33 PM
CTRaptor's Avatar
Default mild 686
Depending on your elevation, a mild kit would consist of a 11:1 piston (12:1 if you want 50/50 race), and a Stage 1 hotcams (theres a web cam one but the HC is better) and thats good for sea level, if your around 4500+ ft do the 12:1 and you can get by running pump 91.
Old Aug 8, 2003 | 01:34 PM
HoundDog06's Avatar
Default mild 686
an 11:1 piston at 102mm with a stage one cam makes a pretty nice combo and still remains a good all-around bike.
~HoundDog
Old Aug 8, 2003 | 01:39 PM
raptor03's Avatar
Default mild 686
I have a craycraft 686 consisting of a 11:1 & a Hc stage 1,head Porting..
I love the power and it rips in the drags and is great in the trails,sand ,desert,etc,etc..
it's gets better with every ride..
Old Aug 8, 2003 | 05:17 PM
ccgrady's Avatar
Default mild 686
I'm at 6500 feet. So if i go with a 12.1 piston and a hot cam stage one that is all i have to do? please any input is great.
Old Aug 8, 2003 | 06:44 PM
PatsRaptor's Avatar
Default mild 686
I'm at 5200 feet running a 12.1 stock bore,stage 1 cam and porting. I run 101 but I could run 91 pump if I wanted I just like the better fuel!
you can go with stock bore 100mm or 102mm 686 but you will still have to have to bored to the RIGHT spec!
ccgradt I'd get to ported also it makes all the world!! The power is amazing!!!!!!
Old Aug 8, 2003 | 07:51 PM
ccgrady's Avatar
Default mild 686
how much does it cost to have it ported and secound if i keep the same size bore but increase the compression with stage one cam will it be a noticeable difference.
Old Aug 8, 2003 | 08:11 PM
wshrdskin's Avatar
Default mild 686
yes it will and it will be almost as noticable as a 102mm bore. Porting will be around $400 or so depending on where you get it done.
dakotart
Sep 30, 2001 01:56 AM
lonestarbanshee
Sep 28, 2001 02:16 PM
madweazl
Sep 11, 2001 11:26 PM
