Hopefully not so big problem... HELP!!
Old Aug 9, 2003 | 05:46 PM
Pogo's Avatar
Default Hopefully not so big problem... HELP!!
I adjusted my floats because it was flooding when it was in a wheelie. When I put everything back together and started it up it wouldn't start at first then when it finally started it had a very high rev. What did I do wrong? Did I move them too far. help! Thanks for the help.
Old Aug 9, 2003 | 05:53 PM
sixsixT's Avatar
Make sure you didn't twist the throttle a choke cable.
Old Aug 9, 2003 | 06:08 PM
Pogo's Avatar
I just checked. you may be right. When I worked on the carb I took the carb completly out and took the choke cably out of the carb. Is there a certain way to put it back in?
Old Aug 9, 2003 | 06:13 PM
ALIENraptor's Avatar
no you just screw it in, apply some motor oil to it, mine was very drie. Make sure it moves in the bore freely. Take the covers off the left carb where the needle slide is, take out the slide and youll see the choke make sure it fully closes
Old Aug 9, 2003 | 06:22 PM
Pogo's Avatar
Nope the choke is is in all the way. So may I have messed up the level of my floats?
Old Aug 9, 2003 | 07:09 PM
Pogo's Avatar
Please?
Old Aug 9, 2003 | 07:14 PM
RacinJason's Avatar
Do you have free-play on the throttle?
If not adjust your idle **** or adjuster at the throtle assembly
Old Aug 9, 2003 | 07:18 PM
Pogo's Avatar
If set the floats to high it spudders during a wheelie. If you set it to low What will happen?
Greenbaron
Aug 8, 2019 08:25 PM
barbarryan
May 15, 2008 12:50 AM
rebeltaz
May 12, 2008 12:11 AM
aceisback
May 11, 2008 10:04 AM
PEGGYSUE
Jan 30, 2004 11:29 AM
