How often should i u know maintanence my Warrior
Old Aug 10, 2003 | 11:30 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default How often should i u know maintanence my Warrior
Last tiem i had my warrior maintanenced was dman near 2 weeks ago ssoo whe ndo u think i should maintanence it again?? it gets ridden about 10 horus a week or more...
Old Aug 12, 2003 | 11:09 AM
shlekter's Avatar
ne 1
Old Aug 12, 2003 | 11:28 AM
warrior007's Avatar
Depends wether you are paying a shop to maintenance it, or doing it yourself.
You should probably change the oil at 20 hours or so, also grease everything up. Valves can go a little longer before needing checked, and probably wont need adjusted for a while after the initial break-in. Keep the filter clean.
Old Aug 12, 2003 | 03:18 PM
MOJAVE02's Avatar
grease and lube chain after every ride. change oil and filter every 20 or so hours. check nuts and bolts and torque wheels every couple rides. check tire pressure and chain slack every ride. and adjust valves every 60-80 hours depending on how u ride.
Old Aug 12, 2003 | 08:32 PM
Speedy2222's Avatar
well i guess i'm overdue i couldn't find chain lube newhere and im gettin soem tomorrow FINALLY!!!!(if they got it) also filter i cehcked aobut 5 hours(of riding) ago and it's clean tire pressure is fine chain slack is alittle bit to much so how would i tighten that?? and were prolly ognna b duing MOST of the work but removing the head and stuff forget that....
Old Aug 12, 2003 | 08:39 PM
shlekter's Avatar
there is 2 8" long bolts that hold your housing 2 your swing arm loosen those not completelyjust so u can c that the nuts are off a little. then u wanna look at the screws that are stickiing straight at u if u r loooking from the bak... loosen the small nuts taht r on them then screw the screws in until the chain starts getting tight it should have about 1' of play whne ur sitting on the quad.....in the manual it gives u thourogh directions also
Old Aug 12, 2003 | 09:27 PM
beatle1's Avatar
Just a tip, I've had my Warrior for 3 years plus and I do a lot of mud and water riding. I unplugged every electrical plug and connection on my quad and found they were full of mud and corroding.
The cylinoid was crusty and green! After cleaning each plug or connection I filled them with
diaelectric gel. It can be bought at most any autoparts store. My qaud is running better than ever.
Also take the lights off and put the gel inside the light bulb socket. I had to take the rear plastic off to get easier access to some plugs. Its really worth the effort.
Good luck
Beatle1
Old Aug 14, 2003 | 01:14 AM
Speedy2222's Avatar
o well im takin it in to get it worked on soon and i got cahin lube so im good on that and ya... u know
Old Aug 14, 2003 | 01:16 PM
MOJAVE02's Avatar
you dont have to pull the head to adjust the valves. just remove the head cover and check clearence with a feeler gauge, very very basic job. if you want to do it tell me and i will talk you through the steps.
Old Aug 17, 2003 | 04:33 PM
Speedy2222's Avatar
well the worst has happened i flipped my quad on FRIDAY 15th broke my wrist and my tail bone i can still walk(and ride my quad) but it hurts lie ka bi otch
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
