Warrior Stock Accel Pump
Old Aug 17, 2003 | 02:41 PM
KILLERCUDA's Avatar
Default Warrior Stock Accel Pump
Is the stock on adjustable? I got my jetting down pack now but she still aint throwin me like she should be. She bogs then if u re it up she'll launch. I think My pump maybe worn or it needs more burst of fuel since I put a lumpier cam in it. Thanks
Old Aug 17, 2003 | 02:50 PM
95wolv's Avatar
The linkage on the pump arm can be bent a little to put the arm closer to the rod so it actuates sooner, another thing to check is the pitiful spring Yamaha put on the pump rod. If you take the side cover off, see if the rod is stuck down. The best fix for this is to take the bowl off, and take the rod out, and replace the spring on the bottom with a click type ink pen spring. it is the same size,but about 5 times stiffer, so it won't allow the rod to stick down, starving your engine for fuel when you hit the throttle. Give these two things a try and see if that helps, it sure made a difference on my Wolverine ,the 95 had the same model carb on it until they went to the cv type carb on the 96 on up Wolverines.
Old Aug 17, 2003 | 03:07 PM
KILLERCUDA's Avatar
Hey thanks I appreciate it. I'm going to go try and find a click pen haha and I'll let ya know how it goes. Thanks
Old Aug 17, 2003 | 04:39 PM
KILLERCUDA's Avatar
Hey Wolv another thing is should I loosen the nut on the arm or bend it? If I bend it looks like I'll break it. I tried loosening that nut but it seems like it doesnt wanna move. But I'm being gentle I dont wanna break anything.
Old Aug 17, 2003 | 06:27 PM
JakalWarrior's Avatar
Could maybe try gluing something on top of of the rod like a lead BB gun pellet then you could slowly file that down till you get it perfect (since you wouldnt even have to take anything apart to adjust it, just leave the dust cover off). Another option would be a big dab of epoxy which can also be filed down if its the right kind.
Old Aug 17, 2003 | 09:55 PM
KILLERCUDA's Avatar
Hey Jakal Thanks for the tips. The devil of jetting has struck again. Remember I had a problem with that bogging from 0 to full throttle? I got my bottom back now but the top end doesnt want to run I'am SERIOUSLY getting pissed off at it. Get yours going any better?
Old Aug 17, 2003 | 10:16 PM
Crotts's Avatar
Sounds like you rich, I had the same problem today with mine. I just put a hotter burning plug in (7) and I think it fixed it. Try that, or you may want to take the clip on your needle up one position
Old Aug 17, 2003 | 11:07 PM
KILLERCUDA's Avatar
I'll try moving that needle up one. Thanks Crotts.
ltrmc02
Aug 22, 2021 02:34 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
essonlaker
Sep 10, 2015 01:12 PM
craacker
Sep 9, 2015 04:32 AM
