Raptor Puke Bottle Issue
Old Aug 18, 2003 | 09:40 PM
FireFly's Avatar
Default Raptor Puke Bottle Issue
When I ride for lomg periods of time in fairly hot temps. the puke bottle fills up then it pukes. After it cools I open the raditator cap, drain the bottle and pour it back in radiator. Just to find later the bottle filling up again. WTF! any ideas?
Old Aug 18, 2003 | 09:47 PM
RaptorRcR's Avatar
It sounds like you have a blown headgasket.
Old Aug 18, 2003 | 09:49 PM
TyreSpinner's Avatar
Head gasket...
Old Aug 18, 2003 | 09:59 PM
FireFly's Avatar
This bike doesn't blow any smoke and there is no oil in antifreeze. any other ideas?
Old Aug 18, 2003 | 10:03 PM
warrior007's Avatar
it doesnt have to blow smoke or have antifreeze in the oil to be a headgasket problem, but it could also be the radiator cap not sealing
Old Aug 18, 2003 | 10:48 PM
wshrdskin's Avatar
As warrior007 said. Also, does your Radiator fan ever come on? Check the thermostat also.
Old Aug 19, 2003 | 12:23 AM
sandRappy's Avatar
I had the exact same problem as you. So I traded radiator caps with another raptor. It seemed to fix the problem. So I would suggest trading radiator caps with someone else first before you tear it down to the head gasket.
Old Aug 20, 2003 | 09:49 PM
FireFly's Avatar
the motor is tore down already after the piston cracked due to flex from a defective wrist pin (too short).
nothing was loose or leaking, the fan does come on periodically but not for very long, no water in oil
Old Aug 20, 2003 | 09:51 PM
FireFly's Avatar
I've already gone through the stripped cylinder bolts and installed the inserts to correct it.
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
