Raptor 12 tooth front
Old Aug 20, 2003 | 04:08 PM
TheRaptorMan's Avatar
Default Raptor 12 tooth front
I have said this before I know, but I swear that I could put that nut on with my fingers, and it would take a freakin impact to get the SOB back off after a ride. I had to add a 1 1/4 1/2 drive and a 1/2 drive breaker bar to the inventory in my trailer just so I could change gears at the track!
Old Aug 20, 2003 | 09:44 PM
FireFly's Avatar
I ran a 12 44 combo for a while and the chain slider was toast after one season of riding. so I now run 13 44 with a lifetime gauranteed T.M. design slider. T.M. will not gauruntee their slider if you run a 12 front sprocket.
Old Aug 21, 2003 | 11:53 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
I figured the slide would wear pretty fast,,,,just curious how fast????
thanks
Old Aug 25, 2003 | 09:33 PM
FireFly's Avatar
I would say after about 40-50 hours. may seem like a while but this is barely a season of riding in my book.
Old Aug 26, 2003 | 07:56 AM
  #15
HappaRap's Avatar
Lazy Boy Rider!
I was running a 12/40, loved it, went to 22's, switched to 12/42, taller tires took alittle from the bottom end, haven't tried this setup out yet. You refer to the slider, which component is that? The plastic peice that bolts to the swingarm that the chain rests on? I know you have the two rollers, upper and lower, the polyurathane peice that's under the chain on the upper side of the skid plate, please enlighten me.
Old Aug 26, 2003 | 07:52 PM
  #16
FireFly's Avatar
The stock slider is that rubber piece that bolts to the swingarm just behind the rollers that the chain slides on. so it doesn't rub on the swingarm
Old Aug 30, 2003 | 04:03 PM
  #17
Rapanator's Avatar
I have 00 and I changed the front to an 11 right out of the box. The back is the stock one, I think thats 42? I only ride in the SAND; I have sand skateII's 20/11/10's. I have not had to break the chain yet. I just adjusted the chain but I'm at the end of the adjustment. As for the slide I only have
normal wear after 3 seasons. I don't know if it's because I clean the chain after every trip and wax it before every ride.We make 8 ,4 to 5 day trips a season thats a lot of hrs. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 31, 2003 | 04:45 PM
  #18
Yam4Life660R's Avatar
I'm fixing to buy a 12 tooth and was wondering if their was a fix to the chain guid wear?Also what happens after it wears out,is it time to buy a new one or what?
Thanks fellas,
James
Old Aug 31, 2003 | 04:51 PM
  #19
BigScary's Avatar
I have a 12 on the front and it isn't wearing at all that I can see.......
Old Sep 1, 2003 | 09:49 AM
  #20
HappaRap's Avatar
Lazy Boy Rider!
My slider has a little wear on it, but still alot of material left, what I noticed going to a 42 on the rear, I had to shim between swingarm and skidplate to keep the chain from riding on the polyurethane material on the skidplate.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
