Raptor 12 tooth front
Old Aug 19, 2003 | 05:17 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default Raptor 12 tooth front
Will I need to modify/adjust the chain guides or anything else??
Old Aug 19, 2003 | 05:20 PM
Courtney's Avatar
I just put one on mine for riding in the sand. Performace was much better. I only adjusted the chain. Everything else seemed ok.
Old Aug 19, 2003 | 09:59 PM
duneittilludie's Avatar
the only adjustment you will need to make is your chain tension.the switch from a 13 tooth front to 12 tooth is a very good way to gain performance and you will not lose as much top end speed as you might think.
Old Aug 20, 2003 | 03:37 AM
Bing's Avatar
Super Quad Patrol
thanks
Im replacing the chain anyhow. I put the 12 tooth on today and it just seemed like the chain guide is going to get chewed up pretty quick.
I like the way it feels so far.
Once I get done the top end shouldnt be too much of a problem.
thanks again
Old Aug 20, 2003 | 06:38 AM
raptor8's Avatar
yeah with those tall tires I did the same to mine. a simple job once ya get that nut loose. It must have been SUMO day at Yamaha when they put mine on!
Old Aug 20, 2003 | 08:42 AM
Murph66's Avatar
I have had no problems or required mods with a 12T although you do lose a little slack adjustment.
Old Aug 20, 2003 | 10:54 AM
Yamaha660R's Avatar
i don't like the high rpm's that you run when you are in 5th gear half throttle...but the 12 is perfect for trail riding. JMO
Old Aug 20, 2003 | 11:08 AM
Guest
Guest
Posts: n/a
how much top speed do you lose? I love acceleratino and hardly ever get to use top speed, most quads I ride with only do 65, besides a few. Anyway will I be topping out at 65,70,72?
Patrick
Old Aug 20, 2003 | 01:35 PM
Bing's Avatar
Super Quad Patrol
It must have been DWARF day when mine was torqued,,,it practically jumped at me.
Old Aug 20, 2003 | 01:56 PM
BigScary's Avatar
mine will do 65-70 with the 12t on it
