blaster control levers
Old May 29, 2000 | 04:21 PM
beatblaster's Avatar
Hi, I'm looking for suggestions on aftermarket control levers both for the clutch and the front brake. I plan on ditching the stock parking brake setup.... I was looking at the msr raptor adjustable clutch lever for use both on the clutch and the front brakes... has anyone tried this? Also the catalog says motorcycle only? What would be the difference?
Leo
Old May 29, 2000 | 05:38 PM
94DGblaster's Avatar
what are you doing to get rid of that parking brake setup?
Is there a kit you buy or is it as simple as buying a new perch and handle, then not running your brake cable up to it.
Old May 29, 2000 | 05:50 PM
Hi, I just purchased the bike, and the rear brake caliper and cable are missing... I found a used caliper and I am going to order a replacement cable that doesn't go to the stock parking brake... more info can be found at http://www.jlatvproducts.com in there online catalog, page 78 under blaster brake kit.
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
tysonbully
Sep 28, 2015 02:30 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
nastyblaster100
Sep 13, 2015 01:19 PM
