ac pro peg instalation
Old Aug 29, 2003 | 09:42 PM
ringer's Avatar
Default ac pro peg instalation
I just got a set for my raptor.when I hooked the shift loinkage to the new brace it went on very tight and now it shifts to hard.Has any one had this problem.Ithink the o ring seated properly.Do you have to ream it out.
Old Aug 29, 2003 | 09:50 PM
RacerRob's Avatar
I had the same problem. The paint on the peg is TOO thick. I just sanded the paint off and it worked better. But then I just went a totally different direction and installed a direct-shifter anyways....[img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 30, 2003 | 09:34 AM
ringer's Avatar
Who makes it and is it easy to install.Thanks for help.
Old Aug 30, 2003 | 02:53 PM
RacerRob's Avatar
There are many companies that make it, so I chose Pro-Design. It eliminates all the crappy stock linkage and connects directly to the counter-shaft coming out of the tranny. Installation is just one allen bolt, but space it tight at the shaft. And use thread-lock so you won't have to mess with it again. Cost is around $80, but you will notice the Rappy will shift easier without all the adjusting. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Sep 1, 2003 | 09:42 AM
UBETRUN's Avatar
I use an IMS direct shifter. Not quite as pretty as the Pro-Design but it's only $30 and works great.
Old Sep 1, 2003 | 12:49 PM
ringer's Avatar
I just ordered roll design.Thanks for help.Ubetrun what kind of a arms do you have.Iam also going to get elkas.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
