Sparks IZ tha SHIZ!
Old Aug 30, 2003 | 03:50 PM
BigScary's Avatar
Default Sparks IZ tha SHIZ!
I put my pipe on Wed night and rejetted it last night.........and all I can say is DAAAAAAMNNNNN.......that pipe is da shiz.....
This is the first time that I can actually hit the rev limiter in 5th.....LoL......I love it.........
welp......I told curtis sparks to send me the correct jetting with the pipe.........and he sent me 160/165 and 27.5 pilots........
I am at 3 turns out and on the third clip........
it feels like it may be a lil fat on the bottom........like if I am runnin WOT and let off completely to an idle........It will die, probably 30% of the time............
and also.....when I'm runnin 3/8 to 1/2 throttle just holding it there at a constant speed in 5th.........it will go "blip" every now and then.......does that sound lean or fat?
What do youthink I should do?
thanx for you help.....!!!!!
Old Aug 30, 2003 | 09:24 PM
BigScary's Avatar
bump
Old Aug 30, 2003 | 09:35 PM
HackerHunter's Avatar
Well written!
...but sry no don't know about that kinda thing.
Old Aug 30, 2003 | 09:39 PM
Come to think of it my quad burps sometimes when about that almost 1/2 throttle in 5th. Doesnt seem to slow me down though!
Old Aug 30, 2003 | 11:31 PM
mick660r's Avatar
i have the same setup as you and also had the same problem
screw the pilot screws in 1/2 to 1 turn and problem fixed
you areright the low end is a bit rich
Old Aug 30, 2003 | 11:33 PM
BigScary's Avatar
do you have any head or engine mods?.......are you running the same jetting 160/165?
Old Aug 30, 2003 | 11:43 PM
mick660r's Avatar
sorry i didnt see your mods
mine is stock internals
i am running dj148/150
Old Aug 31, 2003 | 01:27 AM
BigScary's Avatar
bump....?
Old Aug 31, 2003 | 01:48 AM
WallStreet's Avatar
Mine does this same hesitation you are talking about. When I hold 'er steady at about 4500 rpm it will do it. I think it is a little rich, but I am not too worried about it, I'm gonna have to jejet when I get sixsixt's airbox adapter anyways. About the dying issue, I would recommend putting your stock pilots back in and raising the idle up a bit. It sounds rich on the idle, because after I make a run w/ the nitrous on, it gets real rich becuase of all the extra fuel that got sprayed in there and will die if I don't keep the idles up unitl it clears up. I would say first try raising the idle and if that doesn't work go back to stock pilots. Good luck
Old Aug 31, 2003 | 09:27 AM
garyc660R's Avatar
Since you just paid $600 for Sparks' exhaust, I recommend calling his a$$ up and him fixing it for you. If not....I am sure we can get you worked out...[img]i/expressions/face-icon-small-smile.gif[/img].
