Raptor, Will +2 each side hurt me trail riding?
its not being too wide that causes the problem its being too wide in just the back so as long as you are at least close to the same width on both ends you should have no problems.what i mean is that if your front end is too narrow as compared to the back you will be able to sneak through the tight spots and forget about the back being wider than the front and you will clip trees.
