z440 laid da smack down on raptor
#41
Originally posted by: Yamaha660R
Alba Pipe
Alba Header
K&N Air Filter
No Air Box Lid
= damn close to 50hp.
Alba Pipe
Alba Header
K&N Air Filter
No Air Box Lid
if that were correct then I would be in the 60hp neighborhood........
and a race gas 686 on stock carbs would be around 75 and a 770 would b around 100.........
I don't think so.......
#42
yamaha660 even will the piston and cam if you run into a properly running and modded 450 you will get your @$$ handed to you. Even vs a stock one with the baffle out and lid off you will not make him eat dust, maybe win by a couple bikes. This is if your racing up hills or a shorter race, top end I have no doubt you could beat one with a piston and cam. Where I ride piped 450s can hang with alcohol semi-drag banshees. Im just sayin dont underestimate the 450 cuz they can fly.
#43
#44
The dyno numbers on the YFZ don't blow me away but it hauls as@! It will embarrass many (not ALL but many)built raptors (686's and 720's). With just a pipe, jetting, filter and a cam adjustment it is hard to beat. A big part of it is just that it flat out jumps out of the hole. It is not the baddest but for this close to stock with only 439cc's it flat out stomps.
#45
In 300' the YFZ shines. At Pismo, most of the YFZ's would beat my mild 686 in 300' the track goes a little more and I would start realing most in before we had to shut down. Some were just gone and never to be seen from again. [img]i/expressions/face-icon-small-blush.gif[/img] a 660' race and the storys would be different in most cases. jmo
#46
what's with these dyno numbers always being screwed up, will anybody ever give the true horsepower or anything??
Dyno numbers don't mean $hit comparing this bike in Feb to another bike across he counrty in June.[img]i/expressions/face-icon-small-tongue.gif[/img]
#47
#48
#49
#50
lol- That is what I thought with my Ct Raptor until I got this YFZ. I ended up selling my raptor to a buddy who is 50-60 lbs lighter than me and my YFZ absolutely STOMPS him in a drag race. My rappy was fast also but it doesn't touch the YFZ...mainly in the low end. As far as that Predator goes...it is fast with a pipe/airbox mods and it also would pull the Raptor a little in acceleration(it wouldn't stock) after it was piped but that damn thing is a tank in the woods. I will give it this though...it absolutely would fly down fire roads where the width would allow you to corner with extreme confidence.
