any mchanics???
Old Sep 9, 2003 | 10:58 PM
warriorwasfun's Avatar
Default any mchanics???
is any one a mechanic that can awnser a few question about a warrior? any help would be app.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 9, 2003 | 11:41 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
what's the ?'s i can answer only so many...
Old Sep 9, 2003 | 11:44 PM
you may remember the other night i was asking about a warrior. Well same thing!! i checked the compression with a compression tester and it has about 123# of pressure so that is not the prob, i was wondering if it could be the timing or the valves?????
Old Sep 9, 2003 | 11:48 PM
ypman's Avatar
seems like the valves are working if your getting good compression.
Old Sep 9, 2003 | 11:50 PM
thats what i was thinking. is there any way to check the timing??
Old Sep 9, 2003 | 11:55 PM
ypman's Avatar
I am currently in the middle of rebuilding my warrior, and the only way I know to check the timing is to take the timing chain cover on the side of the head off, and there is a little plastic plug on the case around the flywheel. Anyway you take the plug off and aligh the cam sprocket mark with a mark on the head when the timing mark in the little hole where the plug line up.
What is yours doing as I did not read your earlier post?
-ypman
Old Sep 9, 2003 | 11:57 PM
warrior620's Avatar
I use to have a warrior, whats going on with it??
Mike
long story do a search on Warrior Help!! under my sign on.
Old Sep 10, 2003 | 12:04 AM
warrior620's Avatar
It sounds like you have some trash in your carb which clogged the pilot jet. If its getting spark, has good compression, and has gas in it?? Theres a fuel delivery problem, or if it has spark and its just not strong enough it could be the stator (not to be confused w/ starter).
Take your carb off and clean it and the hoses. Also clean out your gas tank also.
Mike
Old Sep 10, 2003 | 12:07 AM
its got gas dosent even start if you spray starting fluid in carb? i figure even a weak spark would ignite with that.[img]i/expressions/face-icon-small-disgusted.gif[/img]
