Bypassing the ignition switch/Banshee
Old Jun 4, 2000 | 06:28 PM
Bad_Banshee's Avatar
I'ld like to remove the ignition swith from my Banshee. What wires do I need to connect to do this? Thanks,
Bad_Banshee
YamBanshee1@aol.com
Old Jun 4, 2000 | 10:18 PM
wolv09's Avatar
on my 88 it had two wires coming off the switch they went under the gas tank and i simply soldered them together and used shrink wrap and tape
Old Jun 5, 2000 | 05:01 PM
BansheeBrad's Avatar
This is correct.
But let me clarify a little bit:
Off the key on all newer Banshees there are 4 wires. 2 of them need to be solder together as it was stated above. The other 2, do NOTHING. If you follow the 4 wires down to the first plug, it only has 2 wires on the other side of the plug. You can also twist and solder all 4 wires together and it will work, seeing how 2 of the wires go no where do nothing.
Let me explain why yamaha does this. On a 4 stroke motor, you have to ground the coil to stop the motor, so the other 2 wires are for that system. yamaha only has ONE key for several quads.
Just my $.02
Brad
ultangler
Nov 30, 2024 01:35 AM
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
