NEW BARS FOR 97 WARRIOR?
Old Jun 7, 2000 | 12:55 AM
kalsobc's Avatar
Bought a used Warrior and the bars have been bent. Looking to buy new bars and need some help as the mail order books list sizes, but without seeing them it is hard to choose. I ride both sitting and standing and would like a bar that are not as high as the the stock bars.
thanks in advance.
Old Jun 7, 2000 | 12:17 PM
hot_shoe_cv's Avatar
I'm using Renthals with their CR bend. The rise is about 3 1/2 " with less pull back than stock Warrior bars, * I believe a little narrower also I don't recall the exact dimensions but I like them much better than the stock ones especially when standing. Like any of the alloy bars they flex slightly reducing the shock to the arms &m upper body.
It's important that Renthals be torqued to the correct specs, which are only 17 ft lbs. The recommended procedure is to torque to 1/2 the total & then torque to 17#. I have noticed that different manufacturers have bars that they call CR bend & they vary somewhat in rise pullback, etc.
Old Jun 7, 2000 | 04:42 PM
YFMRACER's Avatar
THE BEST BEND TO GET FOR A WARRIOR ARE THE BANSSHE BEND. RENTHAL AND FMF MAKE GOOD BARS. IF YOU CAN AFFORD MORE YOU CAN GET KX HIGH BEND PROTAPERS IT'LL RUN YA ABOUT 140 FOR THE BARS AND MOUNTS BUT THEY ARE THE BEST BAR MADE.
Old Jun 8, 2000 | 12:46 AM
NoFear29's Avatar
Renthal Banshee bend work great on the Warrior.
wendal
Sep 7, 2019 06:46 AM
badgerboy1
Sep 26, 2017 06:11 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
