Rejetting for cooler weather?
I am running a FMF pipe and silencer on my Blaster. I am also running it with a Twin Air air filter. In the summer time I change the main jet to a 260 and put the needle on the 4th notch. It was jetted almost perfect. Now, it's getting cooler when I ride, about 40-50 degrees. The guy at Yamaha said to put a 280 in it. I put the 280 in it and check the jetting and it seems like its running way lean from the plug chop. Why would it be running lean? I think it would be running on the rich side. Do you have to rejet for cold weather?
