will i need to bore?
Old Oct 6, 2003 | 05:35 PM
kuz28's Avatar
Default will i need to bore?
if i install a 10.75/1 JE piston in a stock 660. if not, why not? I need to order so please respond quickly.
Old Oct 6, 2003 | 06:09 PM
Flynbryan's Avatar
Theres no reason to need to overbore if all your doing is upping the compression ratio. Just make certain that your getting the "stock" bore piston size. They offer it in several displacements. Just check and make sure your getting the stock bore, and you should have no problems. The only time you need to overbore is if you have cylinder wall damage.
Old Oct 6, 2003 | 06:54 PM
raptor03's Avatar
Just make sure you check the clearences before installing,sometimes they might fit to tight causing it to cease up or the piston sometimes get's hott and expands causing the piston to get damaged or the Rod to weaken because it's a tight fit..
I bored it out to a 686 and i feel more comfortable,i just seen a few issues on rods going and 2 of the bike were running stock bore..
Old Oct 6, 2003 | 07:06 PM
WallStreet's Avatar
Just remember this, you are fitting the cylinder to the piston, not the piston to the cylinder.
Old Oct 6, 2003 | 07:13 PM
Ward660R's Avatar
kuz, you won't know until you get it.
Just like they said you have to check the piston to cylinder clearnce once you get the piston. The you will know if it needs to be bored or not.
Old Oct 6, 2003 | 07:30 PM
XxDumontRaptorxX's Avatar
It doesn't cost that much to get it bored and honed, jsut buy a 100.5mm piston and take it to the shop and have them bore the sleeve to 100.5. The shop i went too they had me bring my piston in as well to get the exact measuremeant. with 100.5 you wont add too many cc's but you will have pleanty of sleeve leftover if you need it later.
Old Oct 6, 2003 | 07:35 PM
BigScary's Avatar
I didn't have mine bored or honed or anything with my stock bore piston.........it made me nervous so it is torn down right now gettin bored and honed for the 686 piston..........
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
