My warrior keeps bogging out when i hit the throttle fast?
ok i let it warm up and when i am riding it, i will come to a stop, put in neutral or pull the clutch in. then i will punch the gas and it will want to shut off. even if i am not riding it, it will want to shut off. it sounds like it might be getting too much air or somehting like that.
i took the carb off and left the throttle cables on and i looked inside to see where the fuel was beeing squirted and it was squirting toward the head cylinder but it wouldn't reach it is that bad
when u punch it and it feels like it is going to shut of or it does shut of there nothing wrong with it all the warior do tat its becaus it a 2 valve 4 stroke with a sh!!ty carb they all do that
#15
You just need to adjust the valves..the nut on the top...play with it until u get it to the right spot..mine always used to do that then i messed with it one day and it quit doing it..and it runs perfect now...and if u mess it up..just get a feeler gauge and look in ur owners manual for what to set it at...
#16
Originally posted by: blaster0315
every warroir does that my brothers warroir does it there nothin rong at all with it
#17
every STOCK warrior does that ive ridden a lot of warriors and every one did that its normal plus they even sed that when they were testing it this year in atv sport mag so i kinda know ok.
#18
Totally normal condition for a warrior if this is occuring when the bike is at idle and you dump the throttle. I had the same concern when I installed the new pipe and the guy at Alba said every warrior they work on does the same thing. If this is happening when your rolling along and you dump the throttle you've got other problems.
house1
Aug 9, 2015 10:49 PM
