raptor oil tank over flowing/won't start
Old 10-06-2003, 10:08 PM
kendawg's Avatar
Default raptor oil tank over flowing/won't start
my raptor won't start and when i checked oil level, it came gushing out of the the dip stick port on top of the oil tank. i'm really freaked out about this, because i'm leaving for little sahara wednesday! please help me! it'a 2002 660 raptor
Old 10-06-2003, 10:21 PM
sixsixT's Avatar
One of the needle valves may have stuck on one of the carbs and flooded the engine. Does the oil smell like gas? Check the air filter and box to see if there's gas that got in there also.
Old 10-06-2003, 10:42 PM
kendawg's Avatar
wow! the oil does smell like gas. how do i fix it? i just bought this bike saturday from a dealer. does this happen often?
Old 10-06-2003, 10:59 PM
warrior007's Avatar
Sometimes when they sit for a while the float needles and seats get crudded up with dried fuel. Sometimes all it takes is a little tap with a screwdriver on the side of the bowl to get rid of it. Other than that clean it out.
Since you just bought it, take it in, should be no more than a day fix if you yell. 3 weeks if you are too nice about it.
ask em to check and make sure the overflow lines are not plugged, it should be readily apparent when your floats are leaking it will spill all over the ground, in rare instances down inside you motor too
Old 10-07-2003, 03:08 PM
Too's Avatar
Too
Too is offline
My rapotor does the same if i check the oil right after a ride...is this normal or should i beable to stop the engine and pull the dipstick out of oil tank and not have oil come out.....I have ran about 3 tanks of gas through this atv...Have i damaged the motor?
Old 10-07-2003, 03:34 PM
RaptorOwner's Avatar
Yes, I would take it to the dealer and let them fix it. Thats too new of a bike to start working on it.
Steven Bandemer
06-09-2015 08:50 PM
bucklove007
06-08-2015 07:28 PM
garyt1975
06-05-2015 08:53 AM
1000gade
05-27-2015 12:37 PM
RaptorGuy01
10-31-2000 04:23 AM
Quick Reply: raptor oil tank over flowing/won't start
