Advance-Retard Timing /w Stage 1 HC on Rap?
#21
I agree with 007 on that e-bay thing. About the only way I know to get rid of the rev limit is with an aftermarket ign.
I am not sure what I think about the retarded timing for you either. On one side I see being good and on another not so good. If you are exp. detonation (which I bet not) then deffinately good, but if not I don't know. If it burns slower, like methanol, then I would say not good.....I am curious though and will have to think about that one. I can see it helping it rev more though.
#22
THanks for the reply's gentlemen! Turning the sparks key around will give you nothing....just like the stock key. It's flat on 1 side and has a notch in the other. I am actually using a sparks timing key NOW in the backward position because I lost the original and had it laying around from previous usage.
#23
Slim, I have been thinking about this. (Of course this is all my opinon) I think you can get more from advancing the ign. timing over retarding it. I don't know exactley what half of the additive you are using is, but the other half of it I know. Everything I can find on that points out that you would need to make increases in ign. timing.
I think the optimal thing would be a DYNA ignition that you can program your own ignition timing into. You would be able to make changes and check them against your times. Don't you grow money trees up there??? [img]i/expressions/face-icon-small-wink.gif[/img]
Check you PMs for some links supporting what I am talking about.
This seems like a good thread.[img]i/expressions/face-icon-small-cool.gif[/img]
Gary do you know what you are going to do? Did you ever try the adv key in the right direction? Got another one laying around?lol
#24
The Sparks key notch is offset 6 degrees which will either advance or retard timing 6 degrees. The 6 degree offset key offsets the fywheel from were the stock key positions it; thats why the Sparks key has the offset notch and the stock key does not. The stock key and Sparks key are different; I ran the Sparks key when my bike was stock. Slim
#26
I was thinking if you install the key in one way it advances the timing by offsetting the flywheel and if you reverse the key and install the key the opposite way it will offset the flywheel the other way retarding the timing. Is this correct? Slim
#28
Originally posted by: garyc660R
The Sparks key will not retard timing.....1 side is offset and the other is FLAT....just like the stock key.
#29
#30
----_
If you can imagine the above as being the timing key in the correct "advanced" position........the flywheel turns further counterclockwise...effectively advancing the timing. Turn it around and you are back too the stock timing. Hope this helps.
Edit....I had too add 3 dash marks between the exclamation marks for them too show up correct.
