16 Tooth Sprocket For Warrior?
Old Oct 9, 2003 | 12:39 PM
KILLERCUDA's Avatar
Default 16 Tooth Sprocket For Warrior?
Anyone know where I can get one for a decent price? and will there be any problems with the size of the sprocket messing with my cases or guards or anything like that? Thanks
Old Oct 9, 2003 | 12:53 PM
FISHER1648's Avatar
I'm running a 15t and it works good. Dont know if a 16 will fit - havent tried it. It's gonna be tight. The 15t seemed to put a lot of pressure on the bottom chain roller so I took it off....no probs yet.
Old Oct 9, 2003 | 12:58 PM
KILLERCUDA's Avatar
Thanks Fisher, It rips through the gears with these mods but when i want the top end it revs out too fast i dont like doing that. I already have a 14 tooth in there so i need more gear yet the 20" tires messed it up too.
Old Oct 9, 2003 | 02:13 PM
FISHER1648's Avatar
Yep - I've found the 15T front, stock rear sprocket size, and 22" rear tires give a decent top end speed. The Warrior 1st/2nd gear is low and still doesnt lug. Might be too tall for real tight stuff or dunes but seems to work well for overall riding.
Old Oct 9, 2003 | 02:30 PM
KILLERCUDA's Avatar
Hey Fisher I just ordered a 16 Tooth sprocket fron Dennis Kirk they even have a 17 Tooth coming in soon for a Warrior so a 16 should be fine. I'll let you know how it goes.
Old Oct 9, 2003 | 02:32 PM
FISHER1648's Avatar
Cool - I'd be interested in a 16t.......always looking for more top speed [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 9, 2003 | 02:58 PM
95Wolverine's Avatar
You might want to make sure the swing arm still has full range of motion once you install the 16T sprocket. if not, you'll wear out the output shaft bearings in a hurry. I can't remember if the chain is tightest in the fully extended or fully compressed suspension, but check both.
Good luck and better riding.
Old Oct 9, 2003 | 04:31 PM
KILLERCUDA's Avatar
Thanks 95Wolvy I'll do that.
Old Oct 9, 2003 | 04:46 PM
white660Raptor's Avatar
something else you could try is a smaller rear sprocket. its a little more money but you wouldn't need to worry about the chain roller problem and it would give you more clearence. what ever you do good luck!
Old Oct 9, 2003 | 09:44 PM
DogS's Avatar
16 fit noproblem 17 kinda off tight might have to trim case. Sunstar pretty good for testing they hold up well you can get them at dennis kirk.
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
