blaster pistons in banshee
Old Oct 10, 2003 | 09:34 AM
justanotherRAPTOR's Avatar
Default blaster pistons in banshee
in order for to run blaster pistons all i have to do is have the cylinders bored and resleeved for the blaster pistons right?
Old Oct 10, 2003 | 10:02 AM
Hiram's Avatar
I believe so. They have also have kits that come with +4mm stroker cranks.
Old Oct 10, 2003 | 04:03 PM
Imback's Avatar
If you want to run Blaster pistons (wich is a waste of time and money) you need to get your sleeves bored to 0.080 no resleeving is involved.You will also need to run longer rods on your crank 115mm instead of the 110mm stock ones because the Blaster piston pin is located 5mm higher than the stock piston pin.You can run a long rod crank without wasting a nice set of sleeves by boring them to 0.080 Wiseco has been making pistons to match long rod cranks for a while now.
exmotocrosser
Sep 13, 2019 06:12 AM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
