anyone have a craycraft raptor?
Old Oct 22, 2003 | 08:14 PM
newtz's Avatar
Default anyone have a craycraft raptor?
im looking into getting the 686 kit by craycraft, do i need to send them just the top end to be reworked or do they need the whole motor. i can put it back together
Old Oct 22, 2003 | 08:24 PM
wshrdskin's Avatar
Cylinder, head, carb boots and carbs if you want them to tweek the stockers. They'll bore the cylinder to their specs for the piston, gap the rings for it as well. Do a valve job, install the new springs if you choose, port the head and send it all back with the other parts like gaskets, cam and whatever else etc for you to put together.
Old Oct 22, 2003 | 08:28 PM
raptor03's Avatar
Yuppers!
Old Oct 22, 2003 | 08:29 PM
sixsixT's Avatar
It depends on what all you want to have done. If you want it ported and a 3 angle valve job and the intake boots matched they'll need the head and intake boots, if you want them to bore it they'll need the cyl. if you want a rod too you may want to send the whole engine.
Old Oct 22, 2003 | 08:30 PM
raptor03's Avatar
do they put the rod in and balance it too?
Old Oct 22, 2003 | 08:43 PM
sixsixT's Avatar
They'll put the rod in or you can send them the crank to have it put on and balanced or you can just buy the rod.
Old Oct 22, 2003 | 09:38 PM
14mins's Avatar
If you get a new rod it will be balanced. Bob does not half-*** anything. I have seen raptors that did not have the crank and rod balanced and it showed.
Old Oct 22, 2003 | 09:47 PM
sixsixT's Avatar
Yeah I would not recommend just buying the rod and having anyone put it in, and have it balanced for sure.
Old Oct 22, 2003 | 10:38 PM
newtz's Avatar
why put in a new rod? his site doesnt say anything about a new rod with the kit
Old Oct 22, 2003 | 10:48 PM
wshrdskin's Avatar
Because stock rods have been known to disinigrate. I chose not to go with an aftermarket rod after my stock rod disinigrated (not while I had this 686 kit). I may or may not regret my decision one day.
