Venting!
Old Oct 23, 2003 | 01:30 PM
BigScary's Avatar
Default Venting!
Originally posted by: DaBeechMan
thats rough. Sorry man. Might have better luck taking it to a 2-stroke guy [img]i/expressions/face-icon-small-smile.gif[/img]
my mechanic has worked on his two 250rs since he bough them new in the late 80's........he does all of his own work short of bor'ing the cylinder......
Old Oct 23, 2003 | 01:32 PM
BigScary's Avatar
Default Venting!
Originally posted by: garyc660R
When he supposedly got the bore right did he bore the cylinder too the actual piston? He should have. You would probably be shocked how little your mechanic knows over yourself about maintenance.
he had my piston the whole time........JE called for .003 clearence and he made it have .0052.........he fessed up and fixed it....I don't guess I can be had at him........accidents happen.....
but he is also the same person that ordered me the wrong gasket.....
Old Oct 23, 2003 | 01:33 PM
BigScary's Avatar
Default Venting!
Originally posted by: Ward660R
My local dealership doesn't employ any mechanics. They have some "parts changers" who will read the manual and swap stuff out, but they don't know why.[img]i/expressions/face-icon-small-confused.gif[/img] This pretty much forced me to learn to do my own work. Now it is somethig I enjoy doing. You get a better feeling smoking that @$$ when you know that its all because of you.
[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img]
I know exactly what you mean.......that is the same as my stealership.........
I just go in there (when it is still in waranty) and tell them what part I needed.........and I put it on.......
Old Oct 23, 2003 | 01:50 PM
garyc660R's Avatar
Default Venting!
[quote]
Originally posted by: BigScary
he had my piston the whole time........JE called for .003 clearence and he made it have .0052.........he fessed up and fixed it....I don't guess I can be had at him........accidents happen.....but he is also the same person that ordered me the wrong gasket.....
The recommended clearance is PER INCH OF BORE FOR THE JE PISTON. The Rap has real close too a 4" bore. You should be around .016-.018. Give him a call
Old Oct 23, 2003 | 03:10 PM
  #15
ba01raptoraz's Avatar
Default Venting!
what is a 'cfm drop kit'? unless I'm misunderstanding this, why would you want to lower the cfm?
Old Oct 23, 2003 | 03:27 PM
  #16
Hiram's Avatar
Default Venting!
And don't forget to have the rings file fitted in the bore to the proper clearance, JE rings are a little tight and the ends need to be filed some, or they will butt and you can break the rod.
Old Oct 23, 2003 | 05:10 PM
  #17
BigScary's Avatar
Default Venting!
thanks for the tip hiram
My mechanic did that for me yesterday..........
the gasket came in today so MAYBE I will have it tonight.......I don't see what it will help considering I have class tonite....but I could sleep in the garage with it or something.......[img]i/expressions/face-icon-small-happy.gif[/img]
the drop kit lowers the front of the quad........(cfm is the manufacturer)
ReconBayou
Oct 31, 2022 05:37 PM
SDR-II
Sep 29, 2015 01:06 AM
bvolks
Sep 13, 2015 12:57 PM
KSJOHN
Aug 30, 2015 08:15 AM
Captjay
Jul 23, 2015 12:33 PM
