How do you know what octane to run?
Old Nov 12, 2003 | 08:36 PM
  #21
thomez's Avatar
Default How do you know what octane to run?
Choky
If that is the lowest you can get, that will be fine.
Thomez
Old Nov 12, 2003 | 09:03 PM
  #22
PUSHINTHELIMIT's Avatar
Timing of the motor also plays and important role in octane/compression situations. An example of this for instance my DS650 motor has the same 9.7:1 compression ratio and it requires 91-93 octane. Now my cousins's YZF440 motor is 12.5:1 compression and he can run regular 87 octane fuel without a problem. Now these are two different motors with different timing. I'm not exactly sure but if I can recall the more advanced the timing is in a motor, higher octane fuel is needed. So a motor with more retarded timing will allow you to run lower octane fuel.... Assuming 2 motors have the same compression ratio, but one has higher advanced timing will need higher octane, and the one with the more retarded timing will be able to run lower octane.
every stock quad will run on premium unleaded but 11.5:1 is ABOUT the limit for 93 octane but depending on what quad it is you can sometimes run a 12-12.5:1 on 93 octane.... It's about the timing.
Polaris-400
Aug 19, 2015 02:20 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
ranvette
Jun 10, 2015 09:57 PM
Tree Farmer
May 6, 2000 03:36 AM
