2001 Warrior Problems
Old Dec 6, 2003 | 12:14 AM
caliboy's Avatar
Default 2001 Warrior Problems
[img]i/expressions/face-icon-small-blush.gif[/img] I am stuck. My warrior is having issues with running. After it heats up for about half an hour, it dies and won't re-start for about 10 minutes. I found so far that the gas cap isn't the problem, it has spark and tries to crank. it smells like I have gas, but it won't start. Has anyone ever had this problem and if so can you help?
Old Dec 7, 2003 | 05:45 AM
Boxhead's Avatar
I can't say for sure, but my first guess would be the fuel mixture is a bit lean causing overheating and poor starting. You would possibly hear backfires in the exhaust, or possibly a pingy sound when the engine revs higher than idle. The engine won't rev out when in the top end if a lean condition is your problem.
Old Dec 7, 2003 | 09:18 AM
warrior68man's Avatar
Are you sure your taking the choke off? lol
Hey, mine got stuck on time and did the same exact thing almost....
I can't say for sure what it might be...
Old Dec 8, 2003 | 06:41 PM
caliboy's Avatar
Thank you, It does have those symptoms. I don't understand that much about carbs and mixture yet. I will try having that adjusted.
Old Dec 8, 2003 | 06:43 PM
caliboy's Avatar
I have been checking the choke and the ladies that have been learning on it were leaving the choke on at first and keeping the fuel selector in Res then running it out of gas so I have checked into that. Thanks for the tip.
Old Dec 8, 2003 | 07:31 PM
Boxhead's Avatar
You must first purchase a warrior book from a company such as Clymer which shows the complete assembly of the bike in stock form, then you can learn to adjust the carb needle and richen the fuel mixture. I highly recommend the Edelbrock pumper carb as a mod in the future, its so much simpler to do these changes externally. It really brings out the potential hp in the warrior.
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
Reactant
Jul 16, 2015 10:29 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 03:10 AM
