I need advice
Old Dec 11, 2003 | 11:24 PM
DIRTYJOE's Avatar
Default Gaskets?
I was replacing that rubber boot between the carb and engine on my 01 banshee and thought while I was in there I might as well throw in some aftermarket reed valves but I was wondering if I should put some kind of sealent on those gaskets. Any body know? I also tore into the Carbs and cleaned them up a bit and I dont know if those gaskets are reusable or not. All replies are appreciated. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 12, 2003 | 02:06 AM
Turtler's Avatar
Default I need advice
Any time you tear into something with a gasket, it is wise to replace them. Gaskets take a set over time under load and never seat exactly the same way twice. Leaks are much more likely trying to save a few dollars reusing gaskets. There is gasket lube on the market that will help seal and prevent tears upon assembly or torquing.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
