365 bore kit for wolvy
Old Dec 20, 2003 | 07:41 PM
eja's Avatar
eja
Default 365 bore kit for wolvy
looking for information on the 365 powroll bore kit. I do alot of trail riding, some pretty rutted out mud bogs and want to move up to some 25'' tires -can't lose hill climbing power- anyway has anyone bored out their wolv with this kit? I saw it for $250. Around how much for the boring? pro and cons of doing this would be helpfull. Do you have to take your bike to the shop or take engine in or what? If you've had this done you can see I need some help.Thanks for the inputon this.
Old Dec 20, 2003 | 09:03 PM
95Wolverine's Avatar
You could go about your project in two ways... one, you take the front fenders, tank, head, and cylinder off. Then, take your cylinder and the powroll pison to a local machine shop (get references) and let them bore the cylinder to match the piston. This is the most cost effective solution of you are even somewhat mechanically inclined. You will not need to remove the transmission from the bike, just the cylinder and head.
Option 2 - take your bike to a local mod squad (bike builder) and let him do the work for you.. much more expensive.
If memory serves me, I believe you should be able to get a cylinder bored for $50 or less.
Hope this helps.
Ride On.
Old Dec 20, 2003 | 11:34 PM
SpDdEmOn's Avatar
Yes 95Wolverine you are correct its about $50 or so because its an .080" overbore and it doesnt require resleeving. Its an 85mm piston. It will run a little hotter and you will need to break it in again. From what Ive heard its a pretty good kit.
Old Dec 21, 2003 | 10:30 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
i was thinking of getting that for my warrior... u know just an xptra kick so i don't gotta spend a shiz load of money on a big bore kit... u guys know where i cna get a cheap kit??
Old Dec 22, 2003 | 01:57 PM
SpDdEmOn's Avatar
The one he mentioned above is probably the cheapest that you are going to find. I
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
