warrior
Old Dec 21, 2003 | 11:17 PM
zues's Avatar
Default warrior
I have a 1994 warrior and when I go to put the quad into reverse, the engine dies everytime.
Old Dec 22, 2003 | 12:06 AM
trailrider500's Avatar
Default warrior
welcome!! bump for the new guy... I really dont know what is wrong with your quad but someone will...
Old Dec 22, 2003 | 12:37 AM
Crotts's Avatar
Default warrior
Your clutch sensor has been disconnected. On your clutch perch there is two sensors with wires coming out, the top one is park brake sensor and the bottom is your clutch sensor. Remove your nose plastic and follow the wires from the bottom sensor on the perch down to the two plugs and I think you will find one has unpluged.
Old Dec 22, 2003 | 10:31 PM
zues's Avatar
Default warrior
I follow the wires away from the clutch and they go into the main wire loom and it is hard to find the other ends.
Old Dec 22, 2003 | 11:14 PM
Crotts's Avatar
Default warrior
The plugs are before the wires go into the loom. Here is a link of what you are looking for Pic
Old Dec 23, 2003 | 12:00 AM
runts's Avatar
Default warrior
Hey crotts does your atv overheat being bored that far.
Old Dec 23, 2003 | 12:26 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default warrior
if it overheats would an oil cooler take care of the problem??? i think i saw 1 on your warrior...
Old Dec 23, 2003 | 01:10 AM
Crotts's Avatar
Default warrior
I never had it overheat yet and I have been riding it pretty hard, but before I did my motor mods I installed my oil cooler. If I didnt have that I think it would most likely overheat
Old Dec 23, 2003 | 01:20 AM
zues's Avatar
Default warrior
Crotts
Thanks for all the info. I will get a chance to look at it tomorrow. I am dealing with the earthquake. My garage and house is a mess.
Old Dec 23, 2003 | 11:03 PM
zues's Avatar
Default warrior
thanks for all the help. Today I found the problem. The switch at the clutch handle has not been working. I bypassed the switch and now reverse works. I will order a new switch and all is good.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
