Electrical problem with Kodiak
Old Dec 22, 2003 | 11:23 PM
Gianni's Avatar
Default Electrical problem with Kodiak
I have a 2000 Kodiak and in the last few weeks it has been acting up. When I turn the key on a have no power anywhere. The battery is only a year old and fully charged. Sometimes I turn the key on and after a few seconds I hear a click and the power is back on. Any ideals on what can be causing this?
Old Dec 23, 2003 | 07:36 AM
atv123's Avatar
Are you grounded?
Old Dec 23, 2003 | 12:08 PM
Gianni's Avatar
Yes , the ground is good and the battery checks out ok.
Old Dec 23, 2003 | 02:14 PM
Mark6's Avatar
A similar problem happened on mine. It turned out that the nuts on the battery terminals were loose. So, check the battery terminals and make sure they are tight. It sounds simple, but sometimes it the simple things that are the hardest to figure out. Good luck
Old Dec 29, 2003 | 01:18 PM
atv123's Avatar
That's EXACTLY right. I just had the same problem last week. My battery terminals were loose and when I tried starting the Kodiak, it would click. A little Dielectric tune up grease and a screwdriver fixed that.
skinnyr6
Aug 25, 2023 02:18 AM
lightninboy
May 16, 2021 09:52 PM
Chocobamofo
Jul 10, 2015 07:46 PM
RedRancher
Jul 10, 2015 06:36 PM
ranvette
Jul 4, 2015 06:13 PM
