grizzly don't start when its cold
Old Dec 24, 2003 | 01:46 PM
1bigbadgrizzlyrider's Avatar
Default grizzly don't start when its cold
I have a 02 grizzly and if the temp gets below 25 it takes about 15 minutes to get it started. Do all of the grizzly's do this or is it just mine. A buddy just bought a suzuki vinson and at 10 degrees it starts right up. I know one thing, the grizzly has a damn good starter because its lasted winters and it still works after all the abuse it gets. does anyone have any suggestions for this problem.
Old Dec 24, 2003 | 01:58 PM
Mark6's Avatar
Four stroke yamaha's are known to be cold-blooded, but your's should start right up. Your choke is not working correctly. I have a kodiak and even at 15F I only have to set the choke half way. Hope this helps.
Old Dec 24, 2003 | 06:45 PM
hondabuster's Avatar
I believe your grizzly has an enrichener, instead of a choke. If it had a choke, it would start better. Some things to check
Clogged starter jet, or passage.
Air leak.
Improperly working enrichener plunger.
old gas.
Spark plug gap too big.
Try to richen up the idle mixture screw, as the temps drop the the mixture will lean out.
Old Dec 25, 2003 | 12:14 PM
Vakero's Avatar
Clean the plug and unscrew the gas cap
Old Dec 26, 2003 | 02:39 AM
i replaced the enricher plunger about a month ago because the plastic nut that holds the spring and plunger in the carb was broke. I had to order the plunger, spring, and nut all as one unit. after i replaced it, i saw no difference. I did have to adjust the enrichener cable a little because even after the engine was warmed up, you could choke it all the way and it would still run. Now it stalls instintly when choked all the way so i think it is working properly. I'm wandering if the carburator is gummed up. I ride often, so i don't know why it would be but i guess you never know. Other than the starting problem, i really like it but it is kind of a pain in the *** when I can't take it ice fishing on cold days.
Old Dec 26, 2003 | 01:19 PM
Id recheck the adjustment on the enrichener. It should not die instantly when pulling it all the way. It should run at a little bit of a fast idle when pulled all on.Have you got a factory shop manual ?
Another thought... do you use the ethenal blended gas? Try using only pure gas, It can be really hard to find n MN in the winter. The blended gas doesnt have the btu content of real gas, and makes cold weather starting harder to do.
Old Dec 31, 2003 | 11:28 AM
thank you for all the information. It ended up to be the valves were out of spec. I adjusted them last night and now it starts right up. thanks again.
Old Dec 31, 2003 | 01:14 PM
What did you find? were the intakes or exaust out of spec.
It always feels good when you can fix your own.
Old Dec 31, 2003 | 01:47 PM
Raptorboy4life's Avatar
I just bought a grizzly and it was snowing in vt (where i bought it) it was about 20 and it started no prob. It is good off jumps for a utility atv.
Old Dec 31, 2003 | 06:47 PM
the intake valves were out of spec. (tight) The exhaust valves were right on
MikeyBoyesq
Nov 27, 2020 02:44 PM
TLC
Jul 1, 2015 08:29 AM
Big600twin
Jun 10, 2015 03:01 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
