is this true?
Old Dec 25, 2003 | 10:24 AM
chrisz250's Avatar
Default is this true?
hey, im planin on gettin 20 inch wholeshots for my warrior, my bro said if i keep my stock tires which are 22s, and get the 20 inch wholeshots ill be slippin off the back?? is this true?
Old Dec 25, 2003 | 10:27 AM
Yamaha660R's Avatar
No, the 20's won't hurt anything. The will give you alittle bit more bottom end to. As if you had geared your bike down.
Old Dec 25, 2003 | 10:29 AM
chrisz250's Avatar
ok, so the bike wouldnt be tilted down to the point im fallin off right? gearing ur bike down, could u explain to me how to do that? please
Old Dec 25, 2003 | 10:39 AM
JakalWarrior's Avatar
Lol, you wont be falling off the back. By gearing down he means your gear ratios will seem lower. Means youll gain some bottom end, lose some top end, and have to shift more. It wont be a very big difference though.
Old Dec 25, 2003 | 10:42 AM
Starky's Avatar
You gear your bike down by changing the size of your sprockets. To gear down you either subtract teeth from the front sprocket or add teeth to the rear sprocket. Subtracting 1 tooth on the front is about equal to adding 3 teeth to the rear.
Old Dec 26, 2003 | 12:03 AM
raptor8's Avatar
just add one tooth to the front and youll prob be close to stock gearing.
Old Dec 26, 2003 | 03:03 PM
dragracer789's Avatar
Dont worry about it buddy. Its not going to hurt nothing, and you wont really notic a diffrence, but you can always buy a new front sproket (1 tooth bigger) for the front and it will make it normal again and mabey even a little bit higher geared than stock.
shimanok2
Jan 29, 2016 07:37 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
