Raptor was running like it was loading up....
Old Dec 28, 2003 | 08:39 PM
Entomber's Avatar
Default Raptor was running like it was loading up....
It seems like the Raptor when not running it wide open it would feel boggy and dump too much fuel in the carb. What would be the best way to lean it out just a bit.....would I need to change the needle?
Old Dec 29, 2003 | 07:06 AM
raptor8's Avatar
maybe your chokes are not shutting all the way off. sometimes the plunger sticks on the RH carb. look at your choke lever from the ground up. is the cable wadded up there? if it is, then the choke is not shutting off - spring prob broken or crud in the tube. Not hard to fix...01s are famous for it- a friend's did it today...
When i fixed mine i cleaned the tube out really well, lubed with teflon, and found a way stiffer spring. that fixed it.
Old Dec 29, 2003 | 09:37 AM
Entomber's Avatar
Thanks for the info.. going to look inside the problem ( I did replace the plunger area including spring). But never the less.. I'll check it out. Thanks!
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
AtvManiac78
Jul 11, 2015 03:20 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
