Dial-a-jet?
Old Jan 1, 2004 | 02:26 PM
warrior68man's Avatar
Default Dial-a-jet?
Are they easy to use and install?....They seem like they would it's just I don't know how you adjust them....I'm thinking about ordering one today but I dunno........anyone have them? how do you like them?
Old Jan 1, 2004 | 03:21 PM
Default Dial-a-jet?
on Rockymountainatv, Must purchase the Snorkel kit to work with the Dial-A-Jet, part #
DJ510.
do I need to order it? cuz on thunderproducts.com it doesn't say anything about me needing to order the snorkel kit, but it says its recommended
so do I really need to? because rockymountain does't carry it.
anyone?
Old Jan 1, 2004 | 04:35 PM
95Wolverine's Avatar
Default Dial-a-jet?
The reason thunder products only recommends it is because the DAJ was designed orignally for Snomobile users.... snow on ground yields very little dust in air. As for the quad world, I would not run mine without the snorkel.. just snags the dust that is in the air prior to it entering into the DAJ.
The adjustment on them is quite simple. There is a brass screw that holds the unit either directly to your carb or to the included zipstrap you can use around your airbox to carb hose. Anyway, simply loosen the brass screw, turn the white adjuster (making sure it clicks into position) and then re-tighten the brass screw. One must make sure that they are tuned properly before adding the DAJ. Then, when adding the unit, drop 2 mainjet sizes.. there must be a lean condition for the DAJ to do it's job. So, if you don't already have the necessary jets, order them when you order your DAJ.. otherwise, you'll spend time waiting on them to arrive, or make that trek to the expensive place (dealership).
Good luck and I hope this answers your questions.
Ride On.
Old Jan 1, 2004 | 04:38 PM
Default Dial-a-jet?
I almost forgot, I do like mine and they are pretty simple to install. I did it the hard way and mounted it directly to the carb.. the simpler method would be to use the zipstrap and mount it to the airbox hose.
I think they help out with the transitions between circuits and smooth out the power delivery.
Good Luck.
Old Jan 1, 2004 | 04:57 PM
Default Dial-a-jet?
hmm....i have to make it run lean.....well....It runs rich now..so is there any place I can order individual jets online instead of buying a big kit? If I can, i'll jsut put it about 5 or 6 sizes down from stock and put the dial-a-jet on...but I dont want to buy a big kit. anyone know of a site I can buy individual jets?
Old Jan 1, 2004 | 05:13 PM
Default Dial-a-jet?
5-6 sizes may be way to far. Like I said, you need to be close before adding the DAJ. otherwise, you might be missing the boat entirely. lol.
I bought my individual jets from Chaparral. http://www.800-841-2960.com will get you to their web site. I ordered mine and did have some difficulties with them sending the wrong ones. I ended up finally getting the last couple I wanted through a local dealership for about $3-3.50 each.
Call around, tell them you are looking for the mikuni large round main jets. They should be able to get em for ya. Any shop that caters to snowmobile riders will have them in stock.
Ride On.
Old Jan 1, 2004 | 05:18 PM
Default Dial-a-jet?
oo...do u know what the stock size for warrior/wolverine jets are?....I used to know but I can't remember off the top my head.
Old Jan 1, 2004 | 05:35 PM
Default Dial-a-jet?
#145 should be the stock main jet size for a warrior.
Good Luck.
Old Jan 1, 2004 | 09:57 PM
SHOTGUN's Avatar
Default Dial-a-jet?
Normaly you would need to go down 2 jet sizes.
If in fact you are rich now probable 3 jet sizes.
Talk to Lorn at Thunder, he'll answer you questions.
STLyamwar
Jul 25, 2020 04:44 AM
jnisson
Jun 14, 2004 07:21 PM
joequad
May 15, 2004 01:39 PM
Vforcer
Aug 8, 2003 01:41 AM
Oxygen
Feb 24, 2003 09:14 PM
