Warrior cutting out
Old Jun 26, 2000 | 12:26 PM
wreckedit's Avatar
I have 2 warriors, a 95 and a 00, I replaced the stock exhaust on the 2000 with a FMF Powercore IV exhaust, and put the stock exhaust on the 95 because the muffler was rusted out on it. I also replace the air filters in both, and put vents in the airbox. Neither warrior was running correctly, the 00 would cut out at full throttle, and sometimes 1/2 throttle, etc. The 95 would not start sometimes, had weak midrange sometimes, not topend other times. There was no consistency in throttle and poor performance. It felt like the timing was off. Do the warriors have timing that can be changed? The only other thing that I can think of is that I put 1-way vents in the breather tubes of the gas cap. Could the breather vents be causing problems?
Old Jun 26, 2000 | 03:06 PM
DunePilot858's Avatar
Stupid question for you... did you rejet your carbs after doing those mods?
Old Jun 26, 2000 | 03:13 PM
wreckedit's Avatar
Yes, started with stock main jet, and went up 2 sizes and had the same problem with all of the jets tried. Put a new plug in and ran it and the plug was not fouled.
Old Jun 26, 2000 | 03:22 PM
yamablast's Avatar
my 98 warrior did the same thing. the housing on the left side broke and messed up the gears and caused to jump time.
98 warrior .40 over bore, high performence cam, uni air filter,dg exuast
Old Jun 26, 2000 | 11:33 PM
quadnut's Avatar
You might be having a fuel screen problem. Remove the fuel petcock (Gas- on/off/reserve -valve) from the gas tank and clean the screens. Did you replace the fuel lines also? Remember to torque everything down?
Old Jun 27, 2000 | 12:42 AM
EasterEgg's Avatar
wreckedit
Try it without the valves in the gas tank breathers. The gas tank needs to breath in as well as out. Good luck
98 SC 500
Old Jun 29, 2000 | 12:11 PM
Mr45auto's Avatar
Had this exact problem on my '98 Warrior. If you have a K&N filter change it to a foam UNI or the stock setup. I dont know what exactly caused it for me but changing the filter to a foam unit cleared the problem up immediately. And yes it was properly cleaned/oiled. I was having a bad miss at anything over half throttle. The flat sport you encounter can be fixed by dropping the needle jet clip a notch or two.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Elkaholic
Sep 6, 2015 02:44 PM
