Best way to clean carbon off of piston / inside head ??
Old Jan 6, 2004 | 10:54 AM
FISHER1648's Avatar
Default Best way to clean carbon off of piston / inside head ??
I'd like to clean the top of the piston and the inside of the head. The valves are installed in the head and I wont be removing them. Whats the best way to clean the carbon off ? The service manual shows using a scraper (looks like a scalpel). I was thinking steel wool or scotch-brite pad....
What works best ?
Any tricks ?
Thanks, Eric
Old Jan 6, 2004 | 12:06 PM
DuneMe's Avatar
I was doing this last night to a couple old pistons!
Get a spray can of brake cleaner (or carb cleaner) at your local auto parts store and a bag of those white towels at Home Depot / Costco / etc.
Takes a little elbow greese but, the edges clean up pretty easily. The center of the piston is usually the most difficult. If you were to use a scraper, I would get a plastic paint scraper from Home Depot or something. I have never felt the need to scrape the top of my piston to clean it. A little build-up isn't going to hurt anything so there really isn't any need to start scraping an aluminum piston.
Good idea to take a close inspection of the under side of the piston to make sure there aren't any cracks in it while you have it out.
Old Jan 6, 2004 | 02:47 PM
dzzy's Avatar
Yeah, carb cleaner works great for dissolving carbon. I usually use a dull old pocketknife with a thin blade to scrape out anything the carb cleaner won't dissolve completely. Pay special attention to the area around the valve seats.
Old Jan 6, 2004 | 05:54 PM
Hozed's Avatar
hey.. the more carbon you have the more compression right? lol
Old Jan 6, 2004 | 05:55 PM
Flynbryan's Avatar
When I had two-strokes we always used oven cleaner to remove the carbon, and other crud from the power valves. It works great, but keep an eye on it. Don't leave it unattended, or it WILL eat the aluminum. [img]i/expressions/face-icon-small-shocked.gif[/img] Works great.
Old Jan 6, 2004 | 06:38 PM
warrior007's Avatar
if its still together you can mist some water in the intake while its running. The water cools the carbon so fast it flakes off.
Old Jan 6, 2004 | 07:24 PM
Hozed's Avatar
really?
Old Jan 6, 2004 | 07:25 PM
Chilly's Avatar
Try using a scraper made from hardwood, it won't damage the piston.
Old Jan 6, 2004 | 08:56 PM
PUSHINTHELIMIT's Avatar
Go to a Marina and pick up some Mercury Power Tuner. Spray it all over and let it soak good then blow it off with an air hose. That's what it's purpose is, to take carbon off engine parts. But it's mainly used to spray in the carb while your engine is running kinda like fogging oil and let it sit for a while. Then you're supposed to start your motor and run it like hell to get that $hit out of there, but it works to clean parts especially with carbon on them.
WilliamBos
Jul 13, 2015 02:11 PM
clsharky
Jul 13, 2015 02:07 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
ranvette
Jul 4, 2015 06:13 PM
