gearing the shee???
Old Jan 7, 2004 | 04:16 PM
miniblaster's Avatar
Default gearing the shee???
i think it seems to be geared a little to low now that i have got some mods done to it, do you guys think i will have the power to pull a tooth higher in the front(15)??i don't wanna loose much acceleration, but i have never messed with gearing, and i'm not sure weather it will help me or hurt me, any help is appreciated...
mini
Old Jan 11, 2004 | 04:26 PM
anyone!!!!!!
Old Jan 11, 2004 | 05:15 PM
BigScary's Avatar
yeah you will have plenty of power.....gear that bad boy up a little......
Old Jan 12, 2004 | 12:54 AM
Ernie660R's Avatar
I worked on a customers Banshee it is a piped and jetted, with a K&N filter, milled the head and advanced the timing. 15 front/40 rear, depending on your weight it should run fine. I weigh 240lbs and it screams.
Old Jan 12, 2004 | 10:12 AM
Hiram's Avatar
Yes,gear it up. I just geared up again and now running 16/41 and it feels alot better than the 15/41. With the 15/41 I was running in the powerband in 6th gear and It was scary as hell with the rear end sliding everywhere and not to mention I was going thru my tires real fast, now with the 16/41 I can run 6th gear and now get a steady 4stroke like pull which is added alot to my top end #'s and when I need to get into the powerband I down shift to 5th and it's scary time again[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 13, 2004 | 01:01 AM
Kiko's Avatar
cool Hiram, glad to see you changed your gear.. Lord knows you needed that extra gear...
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
