axle threads
Old Jan 7, 2004 | 06:49 PM
BigBearFX's Avatar
Default axle threads
when i tried to put axle back on after bearing change the part where you put the nuts on to hold the wheels was all marred. I didnt hit it with anything, it must have been hit by something. anyway the nuts wont screw on, any sugestions on how to fix the threads and or marring?
Old Jan 7, 2004 | 10:51 PM
SOPMODM4's Avatar
I had the same problem with my axle, only mine was from my so called friend taking a fat brass hammer to the end of it trying to install it after a bearing job. I was pissed!! I contacted a local machine shop, and told them my problem, and they fixed me right up. The machinist had to put it on a lathe, and reverse cut the threads, and it worked like a charm, cost about $60.00. Good luck!
Old Jan 8, 2004 | 01:36 PM
BigBearFX's Avatar
$60! grmblbl[img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 9, 2004 | 12:06 AM
SOPMODM4's Avatar
Yeah, $60.00 But what else are you gonna do? I guess you could buy a new Durablue axle to replace it, but hell...that is really expensive. You might be able to get it done a bit cheaper, just check around.
Old Jan 9, 2004 | 12:15 AM
95Wolverine's Avatar
Take a close look at the damaged area. Will this area be under the nut once it has been threaded on fully? If not, you can take a fine File and remove the damaged threads in the area of concern. This will allow you to get the nut started and run on past the bad section.
If the damaged area is the length of the threads, you then have a slight problem. I would still file the beginning so that you can get the nut started, and then with a bit of penetrating fluid, work the nut on a little and then back. Sometimes with a bit of luck, you can get the damaged area somewhat straightend out.
Good Luck and Ride On.
Old Jan 9, 2004 | 12:37 AM
RaptorOwner's Avatar
Had the same problem. Here is the trick my buddy used and bailed me out of an axle. He had me buy two new nuts and he put four grooves in them each in the inside so it looked like a thread chaser you purchase at a mechanic shop. Then he filed the threads like 95Wolverine mentioned. Then with the wd40 he went to town and brought it back like new. You dont want to go full force on the threads just a little at a time. Screw on, Screw off...... hehehehe Just keep the wd40 going and just do a little bit at a time, then after about have way thru the bad section switch to the other new nut that you had cut grooves in as well and finish the job. The grooves you cut in the new nuts are what cleans the debris out of the threads after it cuts it. If you dont understand what I am talking about just pm with your email address and I will send you some pics or drawings.
Later and good luck.
Old Jan 9, 2004 | 10:10 AM
BigBearFX's Avatar
thanx. check yoor pm lol. i think i knoe someone that can help me that would know what ur talking about
no its just the begginning threads, i think its ends around the plac where the cotter pin goes. thanks 95wolverine.
Old Jan 9, 2004 | 09:55 PM
Most welcome.
Old Jan 9, 2004 | 10:08 PM
WISTECH's Avatar
yep pick up a cheap thread file and start sawing .
Old Jan 9, 2004 | 11:24 PM
BigBearFX's Avatar
I gots it to thread on. with the help of a file thanks again guys. went for a short ride in the -15 below weather. woverine dosnt like cold
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Sassinm1
Sep 30, 2015 04:23 AM
1000gade
Sep 9, 2015 04:41 PM
