blaster 14 tooth front sprocket
Old Jun 27, 2000 | 01:22 AM
novaman15's Avatar
on my 2000 blaster i have an fmf pipe and silencer, boyesen reeds, vito reed spacer,uni filter, 18-11-8 turf tamer rear tires, and holeshot front tirres. So far the gearing is stock but my top speed isn't very high and i very quickly go through the gears(1-6 in about 5 seconds)first gear is useless. if i add a 14 tooth front sprocket will i lose to much low end power?
Old Jun 27, 2000 | 02:39 AM
THEXOTIC1's Avatar
I did the same thing to an old blaster> I put 18 inch tires on the bike and changed the countershaft sprocket from a 13 stock to 14 and this made the bike perform like stock speed
Old Jun 29, 2000 | 01:36 PM
xWOMBATx's Avatar
On the Blastercentral page, they say adding a 14 tooth sprocket is a cheap and easy way to go about 5 mph faster. I ordered one and put it on my stock Blaster and I have to say it does make me go a little faster but not significantly faster. It also seems to take a little longer to get to top speed.
-xWOMBATx
Old Jul 4, 2000 | 01:02 AM
JIGA's Avatar
Adding a 14t front sprocket will give you more top end power, the stock sprocket is a 13t, adding a 12t will give you more low end power for hills.
Hope this helps.
Bratman2
Aug 6, 2022 01:42 AM
Frisky2050
Apr 9, 2020 11:19 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
