? Flipping Rear Linkage ?
Old Jan 12, 2004 | 09:12 PM
sixsixT's Avatar
Default ? Flipping Rear Linkage ?
I did a search and couldn't find much. Have any of you done this and how did it work.
Old Jan 12, 2004 | 09:20 PM
BigScary's Avatar
I did it........and ridding it you cant tell a difference.......but it did lower the rear about 2-3"....
It MAY have taken a little travel out of the rear shock.....but if it did it is not enough to notice unless you MX.........and you aren't supposed to use the drop kit for mxing.......
Old Jan 12, 2004 | 09:26 PM
NY02Raptor's Avatar
but how do you get the front end to drop a little to match the rear? id like to lower my COG but dont wana loose alot of riding ability
Old Jan 12, 2004 | 09:36 PM
sixsixT's Avatar
I have some Elkas for the front on the way and wanted to lower my rear to match until I have time to send my rear shock out and have it redone.
Old Jan 12, 2004 | 10:56 PM
trapland's Avatar
I've done this. I have also switched it back and forth a couple times to make sure it was all that. It is. Its probably THE best free mod you can do. It makes a HUGE difference in handling. I dont jump too high, maybe 4 feet up and 15 feet out and have not had any problems. There is some indication of the parts hitting but I dont care. The benefits outwiegh the risk of damage and if I DO break anything, I'll get ELKAS.
Old Jan 12, 2004 | 11:03 PM
sixsixT's Avatar
Sounds good so far. You get twice the air I do [img]i/expressions/face-icon-small-smile.gif[/img] so I should be alright.
Old Jan 12, 2004 | 11:05 PM
LOWBOWTIE's Avatar
[quote]
[i]Originally posted by: [b]sixsixT
Yea me too!
[img]i/expressions/face-icon-small-blush.gif[/img]
Old Jan 12, 2004 | 11:07 PM
Yamaha660R's Avatar
It is very easy to do. Just turn the linkage 180 degree's, and you will drop 3-4 inches. I used the lowering kit on the front, and matches it by flipping the rear linkage. No problem's. The lowering was probaly my best mod to date...other then the pipe.
Old Jan 13, 2004 | 12:08 AM
wildchild660R's Avatar
I did mine and it lowered the rear about 2 inches like they said. I also did it the same time as my 4 inch swingarm extension and after both of them its alot easier to whip the rear end around and I think it corners alot nicer. No problems yet and Ive been running it like 2 or 3 dunes trips
Old Jan 13, 2004 | 12:15 AM
sixsixT's Avatar
It gets flipped upside down not front to back, right?
