Warrior Rear Shock Options?
Old Jan 27, 2004 | 03:54 PM
warrior68man's Avatar
Default Warrior Rear Shock Options?
I just found out that it would take too long to rebuild and nto even sure if its possible to rebuild the stock rear shocks on warriors....so....What are some aftermarket choices I could go for?
BTW This guy I know could sell my a works shock pretty cheap...but its needs rebuilt...are they rebuildable and is it expensive?
-warrior
Old Jan 27, 2004 | 04:03 PM
Need some options quickly....I'm trying to still go riding this weekend...and I don't know if I can take usng that blown rear shock again.
Old Jan 27, 2004 | 04:07 PM
rede34m5's Avatar
rebuilding shocks i dont think is very hard. i think it just consists of o-rings and gaskets on the inside and is pretty easy to rebuild. if the works shock is cheap i would get it and just rebuild it.
Old Jan 27, 2004 | 04:10 PM
No....I heard that Wariror rear shocks cannot be rebuilt normally....they can be rebuilt but in a different way and its not 100% gurranteed to work.
Old Jan 27, 2004 | 04:17 PM
kawasaki88man's Avatar
buy a new one
Old Jan 27, 2004 | 04:26 PM
440EX026's Avatar
The warrior rear shock is rebuildable, or at least the one on mine was.
The works should be better but be carefull what you pay for a used shock that needs to be rebuilt PLUS revalved for you if there is a large difference in the weight it would need to be set up for as this is where it can get expensive.
Old Jan 27, 2004 | 04:40 PM
kuz28's Avatar
Rebuild a warrior shock? Dude did you fall off your quad and hit your head? Just get on ebay and buy another for peanuts...or even better....buy a used Raptor shock. that will actually increase travel.
Old Jan 27, 2004 | 04:42 PM
Raptorx44's Avatar
Ditto, better way to go! )01 Raptor shock all the way!
Old Jan 27, 2004 | 05:04 PM
I have been looking on ebay...but I heard most of the cheap ones are usually bad ons that need rebuilt anyway
Old Jan 28, 2004 | 06:46 AM
440EX026's Avatar
Std rebuild (seals, oil recharge) should run from $80-120 depending on where you are etc. So either go cheap and get yours redone or spend some cash and do it right.
Plus in comparison to the fronts the real isnt all that bad, but the fronts are total junk so keep things in perspective and plan on changing the fronts if you have not already.
Bratman2
Aug 6, 2022 01:42 AM
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
