vitos 240 kit for blaster
Old Feb 1, 2004 | 03:06 PM
blasterofdisaster's Avatar
Default vitos 240 kit for blaster
i was wondering anyone who has put this on, is it worth the money, how much faster does it make it, and was it easy to install? thanks.
Old Feb 1, 2004 | 03:49 PM
diaperdude's Avatar
Hey bud this subject has been discussed many times, so do a search under the yamaha forum for Vitos 240 big bore kit?, I think you should find all ya wanna no![img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 1, 2004 | 03:56 PM
uh i search and hade no results so yah
Old Feb 1, 2004 | 03:59 PM
Criminalpoet's Avatar
Dude dont even bother waisting your time and money on the Vitos 240 kit. First off it doesnt even come ported. If you want a real 240 kit done right get it from www.hollywooddirtproductions.com . Hollywood Dirts 240 kits come with everything you need and their ported with either his PD2 design or you can get it maxed out with the PD3 port design. With the PD3 port design he really opens up those ports and on the intake side of the cylinder he cuts custom boost ports and gives the exhaust port a riffled affect which really speeds up the process of scavenging those unneeded exhaust gasses, and I also believe that his kits come with a base plate spacer as well which allows the piston to better uncover the transfer ports resulting in more power.
Also, the head comes with his "Prop" head design and is set up for what ever compression/fuel that you want to run. Go and check out his site youll melt on his port work. Oh and the prices on his 240 kits are better than anyone elses and I can speak from experience being that I have his work. He also does strokers and long rod kits as well.
Old Feb 1, 2004 | 04:02 PM
diaperdude's Avatar
hey my bad do a search under 240 kit, ok there is tons of info i just checked it [img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
