domes for a banshee
Old Feb 1, 2004 | 03:19 PM
lapeerbanshee's Avatar
Default domes for a banshee
i have a 1998 banshee and i was wondering if i should get domes for it i have been reading about them and it says that you can increase and decrease your compression but i dont understand why you would want to decrease your compression how would that help the performance of your machine.
Old Feb 2, 2004 | 12:09 AM
2004LEBANSHEE's Avatar
To use domes you need an aftermarket head. increase comp for more power. Decrease makes you slower.
Old Feb 2, 2004 | 12:31 AM
but why would you want to go slow?
Old Feb 2, 2004 | 12:09 PM
You dont. But say that you have a stock engine and it has a cool head with 20cc domes giveing you 160 compression. Then you want to increase the timeing on your bike by +4 this will cause you comp to go up to a level about 165. This is really close to the point of haveing to run mixed 50/50 race and regular gas. If you dont want to pay 3.55 a gallion you can put in 21cc domes and bring it to like 150 then you are safe on pump gas. Other than that not sure.
Old Feb 2, 2004 | 02:55 PM
AlkyBurninX's Avatar
More compression increases lowend but decreases your topend. So you can drop compression to let the motor rev out more.
Old Feb 8, 2004 | 01:53 PM
oh ok so you have to sacrifice power or speed
Old Feb 9, 2004 | 12:28 PM
Yeah, but do you spend more time at WOT in 6th gear, or at 2000-5,000 RPM?
There is a point where you know what your bike CAN topend at and you stop worring about using it as a bragging right. Instead, you use the fact that your bike makes so much low-mid that it will pick the front end up in third by rolling on the throttle.
Old Feb 9, 2004 | 09:41 PM
i usually ride in the trails but some times i like to drag
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
